Researching landscape 12v transformers and I can't find the answer...
looking at mulri tap with several commons..
For example, lets say a multi tap transformer with 4 internal switches...it has 4 commons c1,c2,c3,c4 and 4 taps, tap1-12v,tap2-13v, tap3-14v,tap4-15v, depending on the tap voltage is that the common you use?
https://www.kichler.com/kichler/pro...rmers/contractor-series-transformer-1200w-ss/
Yet another has internal switches , circuit 1, circuit 2, circuit 3, circuit 4... 4 commons c1,c2,c3,c4... and then multi taps of 12v,13v,14v,15v,16,v17v,18v,20v,22v which common with which voltage ???
https://www.voltlighting.com/low-voltage-transformer-outdoor-lighting-1200/p/VTR-1200P
Also is ETL listed ok or does it have to read UL ?
edit... was just thinking, are the 4 switches switching the 4 commons???
Thank you
Thank you
