I cant seem to get a good answer on running lanscape lighting cable inside a home and I can't tell what 411.4 is stating. I have 2 Kichler 600w trans that are mounted inside a home in the basement right next to the panel that are controlled by a time clock so the customer didnt have to see those large trans boxes outside on there patio.(these Kichler trans are not small) Can the 10/2 landscpe cable run through holes in the joist and exit the basement through a 1/2 PVC sleave to go to the lights? The longest cable run in the basement is about 50' before it exits the home and the other 3 cirs are only about 20'. I just worry about the high amp draw on low volt lighting and the risk of fire. Kichler trans can be mounted indoors (if they have an indoor mounting plate) according to there information online and when I called to verify.Please help
