Landscape Lighting
rbergerUSN
New member
Raleigh, NC
I am installing some new landscape lighting and purchased a transformer - Progress Lighting P8591-31. I also purchased a photocell for the transformer - P8526-31
I have a twp questions about installation/function:
1. Are these two products compatible? The photocell has an easy-connect end but there is no matching terminal in the transformer. There is a wire inside labeled COM which connects to the on/off switch.
2. There's only one terminal to connect lights to - do I split the line outside the transformer to the different runs of lights?
ActionDave
Chief Moderator
Durango, CO, 10 h 20 min from the winged horses.
Licensed Electrician
I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician (or at least a licensed apprentice), then I will reopen your post, and offer an apology for the delay and inconvenience.
