landscape lights
normbac
owner wants to dim landscape lights they have one transformer 100 watt but want to dim two different areas separately. not sure how to do and comply since I cant legally dim a receptacle how would I use two magnetic dimmers to do this TIA
Dennis Alwon
Chapel Hill, NC
Retired Electrical Contractor
You can buy a trany that is direct wired to avoid the plug issue however, you can dim a receptacle but you must use a special receptacle and plug so nothing else can be plugged in. Lutron makes them.
You cannot dim two different areas with one trany. You will need two.
Here is the lutron recep. Here is the link to the site
normbac
Thanks!!! :D
dmagyar
Rocklin, Ca.
low voltage lights
low voltage lights
Dim low voltage lights? Why not install lower wattage bulbs. With only a 100 watt transformer they can't be lighting up much of an area.
normbac
actually they are being used inside a palapa and they want to be able to control the mood :roll:
