ElectricalKennedy
- Aurora IL
- Electrician
Hi all,
First time posting but have used this forum to solve about 2 million problems, so thank you for all your advice and help.
I've got a question concerning cable separation in large scale solar installations...
There used to be a section in the NEC that dictated that single conductors had to be separated by the OD of the largest cable in order to remove derating factors. I cannot find anything similar in the 2020 NEC... have they removed it? I think it was like maybe.... Article 318?
Situation:
I have 8 x 500KCMIL 2kv PV conductors using a CAB style system (not cab though, cant remember the name of it) and there's no way to separate the cables naturally... cant find anything in 2020 NEC.... do I need to space them? or can I use a proverbial blade of grass to separate these things as there's no set requirement?
Situation:
