A large house (12 bedrooms). How do you think I should size a the subpanelbds? Just use the area served for the lighting and receptacle load (and add other loads)? Or calc actual connected load (using 180VA per receptacle which seems an over kill with receptacles spaced for dwelling unit)?
What do you think.
It is a house but there will be a commercial elevator with a 20HP motor (believe it or not) so there will be 3 phase and the main panelbd will be 3 phase. I am trying to decide whether to make the subpanels (which will be load centers) 3 phase or 1 phase. Any thoughts on that, please chime in.
FYI - It is a large house but is a sort of group home for active seniors (high end).
What do you think.
