MNSparky
 - Minneapolis, MN
 - Electrical Contractor - 2023 NEC
I recently looked at a job where the homeowner wants us to lay electric floor heat in his kitchen, dining room and hall all controlled by a single thermostat. The total square footage is about 600 sq ft. I have a lot of experience with floor heat, but I've never done one this big.
The kits that that I normally use only go up to 220 square feet which is a 10.7A load at 240V. Here are the issues I'm running into:
- I could use three of these kits and tie them together at the stat, but the stat is only rated at 15A. Can't do that.
- I could use the stat to control a 40A contactor but then I would loose the GFCI protection provided by the stat and the HO would hear the contactor pulling in and out.
Right now, I'm thinking I'll have to do the contactor and mount it in the garage where it won't be as noticeable. I'd also have to feed the contactor with a 40A GFCI breaker in order the get GFCI protection on the heating leads.
My questions are:
Does anyone know of a system that will do 600 sq ft easier than the above system?
Does anyone see a better way to make my system work?
Thanks!
My questions are:
Thanks!
