greenspark1
- New England
Hi,
We are planning to put 4x 300HP 480V motors on a new 2000 kVA utility oil-filled transformer. At 2400A rated output, the transformer can handle the full load amps (365A/ea), but the starting current could be an issue. The motors have soft starters from the factory but I don't have specifics of the magnitude of the inrush. They are each getting a 600A fuse (from the manufacturer) and a 700A circuit breaker upstream.
I am trying to convince myself that inrush won't cause a voltage dip that will affect other systems on the transformer. Any resources/calcs others have used to determine the right xfmr size in similar applications? Thanks!
