Large Scale grounding Systems
There isn't really much you need to know or do other than run egc's as you normally would with any AC combiners and feeders. Pretty much everything these days structure wise is all approved for grounding and bonding so most of it takes care of itself.
If it is an interest to learn the theory part with some practical
Green Book™— IEEE STD 142™-2007, Recommended Practice for Grounding of Industrial and Commercial Power Systems
Emerald Book™— IEEE STD 1100™-2005, Recommended Practice for Powering and Grounding Electronic Equipment
but as electrofelon said, if you use listed structures you are mostly covered.
Grounds for Grounding: A Circuit to System Handbook Book by Elya B. Joffe and Kai-Sang Lock is one of my "go to" references.
