machodelmonte
- Port-au-Prince, Haiti
Hi all,
New to the forum, thanks in advance for any help!
I am running a diesel micro-grid selling pre-paid power, with smart meters, to a remote town in Haiti. (Check out the project here: www.sigorahaiti.com or a video of what we do here) The grid serves 700 small customers with lines we have run throughout (we have a concession from the Haitian government to operate as a private utility). While we plan to eventually move to a 3-phase grid with medium (13.2kV) distribution, we are currently powering the town with 120/240 since the distances are short and loads are low.
We are currently powered by two generators, a 25kW and a 35kW, both putting out 120/240 split phase. However, the 35kW is getting too small to handle the large loads at night, which sometimes peak at 37kW, and growing all the time. We are about 2 months away from ordering two 3-phase 100kW, installing transformers and high-voltage lines. To tide us over I would like to rent a genset from the local Caterpillar dealer. They can offer me either a 40kW monophase genset, or a 75kW tri-phase genset. They tell me that over 40kW they do not have any monophase gensets.
The CAT people tell me that they can offer the 75kW "wired 120-240", which I am assuming means high-leg delta (no one seems to know for certain), but say that that would restrict the load to 50kW. My initial reaction is that loading a high-leg delta connection up that high, with no 240-loads whatsoever, would be bad for the alternator.
So my question is: is there a way to wire 3-phase as '120/240' other than high-leg delta? And secondly, can it be healthy for the generator to run exclusively 120V single-phase loads close to the full rated capacity of the genset?
Thanks much!
Thanks much!
