dickricker
- Eugene, Oregon, USA
Hello,
New to this forum. New to specifying large transformers.
Starting with the load and working backwards.
Two 600 HP, 480 VAC, 60 Hz, three phase motors. NEC FLC = 720 A. Nameplate FLA = 656 A.
Using NEC FLC for branch (single motor) conductor and breaker sizing
720 A x 1.25 = 900 A
350 kcmil at 75 C : 310 A. Three runs (separate conduits) of 350 kcmil = 930 A. OK!
838 A soft starter, good for 2933 A for 30 sec starting, set for 3.5 x 656 A = 2296 A current limited starting.
720 A x 1.75 = 1260 A. Using motor duty 1200 A three pole breaker (Siemens ND63B12).
One 7.5 KVA lighting transformer, 480 VAC, 60 Hz, single phase, 16 A full load current, 30 A two pole breaker
Feeder (combined load) conductor
900 A + 720 A + 16 A = 1636 A
300 kcmil at 75 C : 285 A. Six runs (separate conduits) of 300 kcmil = 1710 A. OK!
Feeder (combined load) breaker
1200 A + 720 A + 16 A = 1936 A
Next standard size lower = 1600 A
Since this is so far below, better use 100% motor duty breaker.
I think that I am good to here. Any comments?
For transformer sizing, I am using nameplate FLA (656 A) and estimated 8 hour average load (80%)
656 A + 656 A + 16 A = 1328 A
1328 A x 0.80 = 1062 A
1062 A x 480 V x 1.732 / 1000 = 883 KVA 8 hour average transformer load
So, 1000 KVA transformer. Do you agree?
1000 KVA Delta to Delta transformer. Secondary: 480 VAC, 60 Hz, three phase, 1204 A
Following NEC Table 450.3(A) or 450.3(B), secondary breaker 125% full load current, next size higher
1204 A x 1.25 = 1505 A : next standard size higher = 1600 A
This matches the 1600 A breaker from the feeder (combined load) determination;
and the conductors (1710 A) are good too.
Am I good to go with this set up?
Now, Question 2:
240.21(C)(3)
Less than 600 V primary with 125% fusing or breaker.
(This would be for a South Korean installation, 380 VAC, 60 Hz stepped-up to 480 VAC, 60 Hz)
Industrial installation, secondary conductors not over 25 feet, well protected.
Can I remove the 1600 A breaker and run the feeder (combined load) conductors directly to the transformer?
Now, Question 3:
Does 240.21(C)(3) apply to greater than 600 V primary with 125% fusing or breaker?
(This would be for a USA installation, 2400 VAC, 60 Hz stepped-down to 480 VAC, 60 Hz)
Thank You! I greatly appreciate your input.
Now, Question 2:
240.21(C)(3)
Now, Question 3:
