Large utility room?___on laundry circuit??
Thank You!! Doing a complete rewire to house built in 1938. At some point, the back porch(10x12) was closed in to make (what I consider) the laundry area. Washer and Dryer already installed in this area. If I do run a seperate circuit for the other outlets, what does it fall under?? (general, afci, gfci)
If you run other circuit(s), it would just be general unless the other part of the room qualifies as one of the required circuits. For sure it will not be AFCI as Tn only requires AFCI protection for bedrooms.
Thank You very much. I am trying to learn and appreciate the people in this industry that helps me to do that. Just want to do the safest install at a reasonable cost without having to many hiccups.
