Alwayslearningelec
- NJ
- Estimator
For large feeder sizes how does the field/PM go about coming up with the footages when buying? Not the estimate I'm sure lol. True tape, company shop drawings?
At least it was extra an not less. Don't you risk being short if ordering off the estimate, then your screwed. 80'-100' extra is not bad if the run is 600'+. Also if there are no conduit routings shown and it's a long run you should def not order from estimate.We've done both methods, true tape or ordering off of the estimate. IMO the true tape method is the only one you should use unless your foreman is highly motivated to sell scrap copper. We've had jobs where there were 80'-100' extra feet of 750 aluminum left on the reel when ordering from the estimate.
And how exactly is that done? You have to have the run laid out first then you use a tape measure?For us it was always a field measurement for the larger sizes.
Yes if you order from the estimate you never know what you're going to get which is why I was saying not to order off of the estimate. You need to pull in something to get the rope in the pipe so it might as well be a true tape. Problem is with some foreman cannot be trusted to be honest. They'll add on their vig, you know 50'+ extra feet on every run to buy a house in the Poconos with the scrap money.At least it was extra an not less. Don't you risk being short if ordering off the estimate
Thanks you. Wow. I wonder if anyone puts labor into their estimate for true taping. I never did or was told to.Yes if you order from the estimate you never know what you're going to get which is why I was saying not to order off of the estimate. You need to pull in something to get the rope in the pipe so it might as well be a true tape. Problem is with some foreman cannot be trusted to be honest. They'll add on their vig, you know 50'+ extra feet on every run to buy a house in the Poconos with the scrap money.
On one project we had an apprentice who was pulling in the true tape. The foreman didn't trust him with the numbers so he told him to just get the true tape from end to end. The apprentice would pull of an extra 40'-50' of true tape and stuff it up into the pipe so when the foreman read the numbers he would over order. The apprentice would then take the scrap. On big projects scrap copper is often a big problem that the boss ends up paying for.
Do you put dragging out the conduits to get the rope in as lart of the estimate? If so you just pull in the true tape with the drag so there is really no additional labor cost.Thanks you. Wow. I wonder if anyone puts labor into their estimate for true taping. I never did or was told to.
That could be over $5k if the run is four 500 kcmil copper.80'-100' extra is not bad if the run is 600'+.
No don't include drag line.Do you put dragging out the conduits to get the rope in as lart of the estimate? If so you just pull in the true tape with the drag so there is really no additional labor cost.
How is pulling in the pull rope estimated, is it part of the wire pull units? If so then you're covered for a true tape.No don't include drag line.
Not exactly sure but think it is...How is pulling in the pull rope estimated, is it part of the wire pull units? If so then you're covered for a true tape.
