hardworkingstiff
- Wilmington, NC
What is the largest breaker I am allowed to install in a 225 amp, MB, SQD panel?
Thanks,
HWS
Thanks,
HWS
Wow I'll have to check in to that, I thought that 150A was the biggest QO. Any bigger and you would need an I-line panel.paul, QO and QOB type breakers that are 150, 200 and 225 amps are available. They take up two spaces per pole.
Please elaborate.Originally posted by iwire:
You did not say plug in or bolt on, if it is bolt on anything larger than 100 will need a sub feed kit.
Actually, I thought I remembered a post in here a couple of months ago when someone had mentioned a % of the MB that you could not exceed. I guess I remembered wrong.Originally posted by iwire:
