Joe Spellman
- Sr. PME & Master Electrician
I have a 63 amp Laser welder that needs to be connected to a 480 volt electrical service.
The NEC addresses a standard Arc and resistance welder.
it does not address a high speed seamless laser welder anywhere i can find.
Are there any changes that can be made or addressed to modify or adjust the OCP and wire size for this circuitry?
OR, do we continue to treat this as a single ARC welder with minimum 200% OCP and 125% wire size?
Your help and response will be greatly appreciated.
Thank you,
Thank you,
