ryan_618
- Salt Lake City, Utah
There is a new wiring method that can be directly applies to a wall and then painted over. It is a sort of "ribbon" with conductors in it. What code section addresses its use?
Pierre C Belarge said:I cannot wait to see this in display at Home Depot or other big box stores. This is going to be very interesting.
There is a website for this company with installation instructions provided.
Revision: Article 382 Nonmetallic Extensions
Article 382 has been revised to incorporate provisions for concealed flat nonmetallic extensions. A new definition of this type of concealable flat nonmetallic extension has been added in 382.2. The article has been expanded to include specific product listing requirements in 382.6. Sections 382.10 and 382.12, covering Uses Permitted and Uses Not Permitted, have been revised and expanded to incorporate requirements and restrictions for concealable flat nonmetallic extensions. A new Part III has been added to Article 382 and provides specific construction specifications for concealable flat nonmetallic extensions. New technologies, consumer electronics devices such as flat panel televisions and custom audio systems, along with ever-changing lifestyles have increased the need for additional power outlets and the desire to place power or lighting outlets where needed to obtain functionality as well as an aesthetically pleasing environment. Often these changes are poorly accommodated through the use of extension cords that are easily damaged, misused and can lead to electrical hazards. This new type of concealable flat nonmetallic extension incorporated into Article 382 provides a safe and reliable alternative for existing occupancies that can reduce the misuse of extension cords, overload power taps, and so forth (see figure 7).
Pierre C Belarge said:Celtic
Did anyone ever tell you that you look like Alfred E Neuman?![]()
don_resqcapt19 said:I see that I am incorrect...the grounded conductor somehow encloses the ungrounded conductor, and then the grounding conductor is to cover all of it...at least that is what it looks like in 382.104 in the draft copy of the code.
Don
don_resqcapt19 said:I believe this is a Southwire product.
Don
