last chance
don_resqcapt19
Illinois
retired electrician
You have until tomorrow at 5pm to get your comments to the NFPA. This is your last chance to have an influence on the next edition of the NEC. You can submit them online here, but you do have to download some software.
Thanks Don. I did see the CMP proposal to change 110.26 relating to exit space and width of equipment. I thought the 2005 code was correct, this was your proposal I belive.
My one 2008 code proposal on use of green wire for a green traffic signal lamp was rejected, my comment on that didn't make it as the fax jammed in the fax machine and I didn't get to resend it
Tom,
Yes that was one of mine for the 2005 code and it has been restored to the 2002 language in the 2008 ROP. We will have to see what happens in the ROC. On my original proposal it was rejected by a wide margin in the ROP, but passed 11 to 1 in the ROC.
Don
