sundowner
- West Wisconsin
So I have two separate signals (125VAC) that go into each building on campus - one signal fires a "latch" control relay which closes my Asco 925 lighting contactor - (turning on all my ext. building lights) The next part of the sequence - in the AM, fires the other signal and fires the "unlatch" relay which opens the lighting contactor. (which is mechanically held - fired to open and fired to close)
I want to keep the Asco but would like to replace the two little open style relays labeled - latch/unlatch which fire this.
What can I use that's only one device - I need a relay which will accept two separate inputs to drive two separate output - all independent of one another. Is this possible??
I thought years ago I used a "Finder" brand relay that did something like this but am unable to what I'm looking for right now...???
Any suggestions guys??
