hurk27
- Portage, Indiana NEC: 2008
Re: Laundry receptacles
Rick where do you see "room" in 210.11(C)(2)????
There is no requirement to supply only a room with a "laundry" circuit. The requirement is for only for the laundry receptacle outlet(s) which to me would include only the outlets provided for laundry equipment.
This in no way Say's if we have other equipment that is not laundry equipment in the same room, that we can not provide a circuit for this equipment.
If you have your laundry equipment in the kitchen it would still be code compliant as the NEC does not state "room" in the requirement. If it did and you put your laundry equipment in the kitchen then what would you do about all the other equipment in there?
[ January 20, 2006, 08:34 PM: Message edited by: hurk27 ]
