- Lockport, IL
- Retired Electrical Engineer
Rick, are you suggesting that if I had a laundry room with two separate set of hookups, and I had two washers and two dryers, that I could feed one duplex receptacle near one set of hookups, with no other outlets on that 20 amp circuit, and then use a second 20 amp circuit to feed a duplex receptacle near the other set of hookups, and I can put the overhead light on that second circuit? Are you saying that no matter how many "laundry circuits" I install, only one of them has the "no other outlets" restriction? I don't buy that. The singular nature in the second sentence you highlighted does not restrict its applicability to the first laundry circuit only. If there exists a "laundry circuit," then the "no other outlets" applies to that circuit, without regard to the presence of any other circuit in the entire building.
