Yep and nope, in that order. Yes, it is confusing. No, you cannot serve lights. The branch circuit that serves receptacle outlets for the laundry can have no other outlets than the receptacle outlets for the laundry.Originally posted by triphase:. . . It can confuse people . . . I guess I can serve lighting with also??????????
The "situation" is that you can't include lights. The branch circuit that supplies the washer cannot supply lighting outlets, smoke detector outlets, or any other outlets than the laundry receptacle outlets.Originally posted by triphase:. . . but lets say 11.5 amps washer, 2 amps at the most on lighting, iron 1200 watts = 10 amps "Yep" probably got a situation.
I noticed that too.Originally posted by triphase: I just noticed something. Did you say another recep. is required other than that for a washer???????????
I can't speak to the IRC. But as to whether another receptacle would be required, it depends on where the laundry room is located. If it is in the basement, then you will need a receptacle to serve the basement, and it must be separate from the laundry receptacle. But that is under the requirements for basements, not the requirements for laundry areas.Originally posted by Paul B:. . . doesn't that depend on the size of the laundry room and what else it could be used for? . . . I think there is something in the code to this effect or in the IRC.
No.Originally posted by Paul B:
Charlie doesn't that depend on the size of the laundry room and what else it could be used for? I failed a rought in because the opposite wall was far enough away to be used for other thing such as counterspace. I think there is something in the code to this effect or in the IRC.
By George, I believe he's got it!Originally posted by Paul B:
I should ask these guys to state code sections, could save me a lot of headaches.
