Zyb Member Location Maine Occupation Design Engineer Nov 15, 2024 #1 Can i just use any lay-in lugs to bond to steel frame? would the lay-in lugs (picture below works)? what do you recommend? Thank you
infinity Moderator Staff member Location New Jersey Occupation Journeyman Electrician (retired) Nov 15, 2024 #2 I'm pretty sure that any listed lug can be used. Any reason why you want the lay in style?
Zyb Member Location Maine Occupation Design Engineer Nov 15, 2024 #3 infinity said: I'm pretty sure that any listed lug can be used. Any reason why you want the lay in style? Click to expand... There are flange column and HSS, but it is more convenient in HSS, so I plan to use the Lay-in lugs to the HSS.
