jmsbrush
- Central Florida
How many pounds of impact do you need for a hammer drill to drive ground rods? Soil condtions are good here. Would Ten be good?
Depends on what chuck it has. A 10 pound drill will probably have either SDS-Max or spline drive. You can get a ground rod driver for either chuck. Expect to pay about 50-75 dollars for the driver. Resist the urge to use the chuck itself to drive the ground rod.jmsbrush said:Lowe's has a 10lb on clearance for $236.00 normally $479.00. Its a Hitachi. I'm not sure if they make a ground rod tool for that drill. Or does one size fit all?
