LCP panel question
titan1021
I've got a small restaurant project under way and an LCP panel is called for in the plans. The panel only needs to control the outdoor lighting which consists of
(5) wall packs, (4) recessed lights, and a sign.
The plan only specifies that the LCP be Ca. Title24 compliant with astronomical timer, auto-shutoff, and 2-hour manual override.
I've narrowed it down to one of the two panels below, I'm just not sure which one I need. The only difference as far as I can tell is the PIR low voltage feature.
I'm not sure if I need the PIR feature at that additional cost, I've searched online and even emailed Wattstopper to try and determine what that feature is used for and if it is necessary for my application. I've had no luck with either.
Hoping someone here is familiar with these panels and can give me a brief answer/explanation.
Thanks!
