LDR rooms
anbm
TX
Designer
Is isolation panel required to serve outlets inside LDR rooms in hospital?
We knew C-sections room do require. Thank you.
You will need to check with your AHJ over healthcare facilities. Some areas require it (NC used to for one example) and others do not. As far as the NEC is concerned it is an option not a requirement.
Roger
