First, are you actually dealing with lead pipe? Is it magnetic? With you being in NYC, the pipe could be old enough to be lead. Actual lead pipe hasn't really been used since before WW2. Galvanized steel pipe was predominantly used until copper took over. Now most plumbing is plastic.
lead was used in solder for copper pipe for years. Also lead was used in brass fittings and fixtures. Now solder is lead free. Also brass is lead free. Lead isn't a problem in pipe or fixtures, unless the ph of the water leaches the lead out of the pipe or fixtures into the water. Thirst is what happened in Flint, MI. THey changed water sources, it started leaching the lead into the water,.
You're only concerned with grounding though. So it doesn't matter if the pipe is lead, galvanized steel, plain black steel, copper, or other metal. If its metal of any kind, and more than X amount of feet, it needs to be grounded and/or bonded.
