mcelweec@gmail.com
CMAC1
- NYC
- Electrician
Has anyone tried a leaf blower for conduit fishing,I need to fish a 4" RGC water logged conduit around 600'.
By my calculations (someone check me) that's about 3250 lbs of water if the conduit is full and if its ID is 4". A leaf blower isn't gonna do it.Has anyone tried a leaf blower for conduit fishing,I need to fish a 4" RGC water logged conduit around 600'.
I submit that the volume of water is important. In order to blow the water out of the conduit you have to get the whole volume of water moving. If the conduit were only 6" long the leaf blower would have no problem clearing it.The volume of water is not important. What counts is the pressure head, which in turn depends on the difference in height between the lowest point in the water filled section and the level at which the water will pour out the other end of the conduit. A wet vac can suck several feet of water, while a leaf blower probably does not generate more than a few inches of pressure.
Be that as it may, I think with a ton and a half of water to move (even disregarding viscosity and friction with the walls of the conduit) with a leaf blower you'd have a long wait. ;^)F=ma, v=at, --> v=t(F/M). If you have enough force to lift the water against static pressure, then it does not matter how much water you have to move, you just need to wait long enough for it to get moving.
While I do not. And once it gets moving, it will take just as long to get all the water out independent of what you are pushing it with. I do agree that it will take a shorter time to see water beginning to come out with higher pressure.Be that as it may, I think with a ton and a half of water to move (even disregarding viscosity and friction with the walls of the conduit) with a leaf blower you'd have a long wait. ;^)
I agree you will need more pressure than a leaf blower will give you. go rent one of those big air compressors used in road construction. you will likely need to screw on some kind of fitting to the conduit.
IMO what you are not considering is the inertia you have to overcome to get over 3000 lbs of water moving. Have you ever tried to blow the water out of a garden hose by mouth? The longer the hose, the harder it is.By your reasoning hydraulic lifts and other applications of hydrostatics would not work either.
C'mon, let's set up an experiment. I'll bring the leaf blower. You bring the 600' of 4" conduit. We can use my hose.
Actually, yes, I have done the experiment. If the hose is dead level except for a bit at the far end and totally full of water, I do not have to blow harder, I just have to wait patiently for a longer time for the water to start moving.Have you ever tried to blow the water out of a garden hose by mouth? The longer the hose, the harder it is.
Or remove the water first by a wet and dry vaccuum cleaner ?
