Fulthrotl
~Autocorrect is My Worst Enema.~
- E
here's the situation... i had conduits leaking groundwater into a basement.
solution was to foam the pipes with a waterproof sealing foam, which worked
spiffy. thanks to iwire for the product recommendation. i put drain catheters
into the pipes to be able to periodically remove standing water if desired, but
the pipes don't leak a drop, so that is a nice to have, and not a big deal if not
done.
customer wants to repair the pipes anyway. all good.... so i'm looking at this
solution...... using either the blown in epoxy that plumbers use, or the cured
in place liner.... as some of the pipes are 2", i'm guessing the epoxy treatment
is really my only option other than digging the pipes up.
have any of you guys ever used the epoxy liner on electrical conduits? did it
work for you?
randy
done.
work for you?
randy
