I've been "creating" IES files and various photometry reports for 3 years - without any kind of primer or anyone teaching me. It's challenging to find info on IES files, even after joining IES. I have to create IES files nearly daily for typical office/hospital fixtures, and would sure like to know more than I do. Like; adjusting for lens depth/refraction, compensate for trapped light, how to adjust the LOR, how to look at a Iso-intensity Diagram and tell if it's close or just abstract. I'm not an electrical engineer, but after 3 years I going a base. Book or course, online or in person. Thanks in advance. )
Your creating....how?
Are you manufacturer products or a MAKER?
Toured a plant a life time ago.
Picture a blacked out room, sensors everywhere on the floor or test area.
Test fixture in center point of sensor arrays fixed mounted on plate that could be raised or lowered to different heights to gather the lumen values.
No rules of thumb for trim or lens variations, they simply tested each product they built and generated its IES file.
Went to "
https://www.cooperlighting.com/global/resources/ies-file-downloads", they have IES files on everything.
Here is one random one.
IESNA:LM-63-2002
[TEST]P21689
[TESTLAB]INNOVATION CENTER P2
[ISSUEDATE]03/03/2020
[LUMCAT]PD6V120-60V1GC_16PAR38LED
[LUMINAIRE]HALO 6 INCH RECESSED LED LENSED DOWNLIGHT
[MORE]VERTICAL LAMP, SPECULAR CLEAR TRIM AND PRISMATIC GLASS LENS
[LAMPCAT]16E26PAR38
[LAMP](1) PAR 38 LED 16 WATTS
[BALLASTCAT]CHROMA IN0061
[BALLAST]CHROMA IN0061
[OTHER]INPUT WATTS: 15.00, AMPS:.143, VOLTS:120.02, HOURS OPERATED
[MORE]PRIOR TO TESTING: 2, STABILITY: 30 MIN, TOTAL OP TIME: 3 HRS
[MORE]AMB TEMP: 25.4 DEG C
[_MOUNTING]RECESSED
[_ABSOLUTE]NOTE: DATA SHOWN IS ABSOLUTE FOR THE SAMPLE PROVIDED.
[_ABSOLUTELUMENS]606
[MANUFAC] COOPER LIGHTING SOLUTIONS - HALO COMMERCIAL (FORMERLY EATON)
[_SEARCH_APPLICATION] Indoor, Commercial, Corridor, Educational, Entertainment, Hallway, Healthcare, Hospitality, Hotel, Library, Retail, Ambient, Downlight
[_SEARCH_MOUNTING] Ceiling, Recessed
[_SEARCH_SOURCETYPE] LED
[_SEARCH_COLORTEMP] 3000K
TILT=NONE
1 -1 1 37 1 1 1 -0.520833 -0.520833 0.1
1 1 15
0 2.5 5 7.5 10 12.5 15 17.5 20 22.5
25 27.5 30 32.5 35 37.5 40 42.5 45 47.5
50 52.5 55 57.5 60 62.5 65 67.5 70 72.5
75 77.5 80 82.5 85 87.5 90
0
815 808 800 798 789 762 715 648 563 469
375 293 226 173 134 105 85 70 59 51
43 35 27 17 10 6 4 2 1 1
0 0 0 0 0 0 0
