LED ceiling fixture w/ battery backup
My google skills are failing me.
I need to replace a couple of 4' 2-tube T-12 "wraparound" fixtures that have battery-backup ballasts with LED units; the ballasts are failing. The replacements don't have to look the same, almost anything that puts out light will work as long as it's a single unit. I've found plenty of 2'x4' lay-in panels w/ battery drivers but not much else (they need to surface mount on a plaster ceiling).
Does anyone make such a beast? What should I be looking for?
If you’re looking to retrofit with LED T8 tubes, you’ll need an inverter. They are not cheap. The $250 fixture replacement will be less than buying and installing and inverter.
