I have had a number of negative experiences with LED lighting equipment in which the light sources and the electronic drivers are built into the luminaire and not readily replaced.
I feel that you might do better with a chandelier intended for regular incandescent bulbs.
Simply install LED retrofit lamps of whatever style pleases you, these are readily replaced in case of early failures or if needs change.
If the chandelier contains numerous lamps then I suggest splitting these over 2 switches, with about two-thirds of the lamps on one switch, and one third on the other switch.
This will give 3 levels of lighting.
