Smiley64
- Middleton Wisconsin
When installing retrofit LED sticks in grocery cooler doors the instructions say connect the low voltage DC from the LED driver to the existing ballast secondary wires that run through the door jams to the existing lamp holders. The lamp holders are to be removed and the LED stick wires connected to the existing ballast secondary wires. This is a UL listed product. The existing wire ways also contain line voltage wires for door heaters and for the next LED driver down the line. Is it allowable to have the low voltage DC and line voltage in the same wire way?
