Is anyone here installing LED drivers, above built in cabinets, closed in by moulding?
This stems from a fellow contractor I was assisting. He is putting a 60w driver for 24v strip LEDs (ul listed) that are inside a cabinet, above the cabinets. It's enclosed with drywall on 3 sides and above. Very ornate moulding will cover the front.
The builder insists he has done this hundreds of times with out incident, and I believe him. It was pointed out the obvious fact of accessibility, and heat. You can't reason with the guy.
It's an 8-10 sq ft space and probably won't cause a fire. But probably doesn't work for me.
