LED Driver Sink Current
neoply
Brazil
Hello all. Thanks for taking up your time to read my post.The specs of TI TPS75105YFFR LED driver as the datasheet of http://www.kyniix.com/uploadfiles/pdf9675/TPS75105YFFR.pdf says "constant current sinking" capability is 60-mA.(LED Power supply voltage up to 15 Volts, and Vcc=3.0V to 5.5 V )My understanding is if Sink current is low, then its better as it will not heat-up my LED driver chips.1- I want to understand What is the importance of High (or Low) LED driver Sink current?2- Why we do not talk about sourcing Current instead?Any comments?
170519-2138 EDT
neoply:
I took a quick look at the datasheet. I don't want to study it in detail.
From the diagram I would call it sourcing rather than sinking.
It apparently provides constant current sourcing, and intensity adjustment (obviously meaning current adjustment).
it is a current source (high side switching, anode). its a switch, etc.
led mA range is 3-25mA
Vin MAX -0.3 to +7 (not 15v)
the chip has a thermal pad
it also has limited power dissipation control.
the DSK package will create about 1w of heat (max), which can be a challenge to control chip temp if the chip is confined in small tight space
less amps running through it, less heat it makes.
