Sean.Day72
- Florida
Recently a client upgraded a bunch of old florescent fixtures to LED fixtures.
It came to our attention that a bunch of drivers have failed due to power surges. It is a handful of lights at a time. It's a large facility with a hundreds of 2x2 layin fixtures.
My immediate suggestion was to install circuit breaker connected Surge Protection to the existing panel feeding the light circuits (none existing) and possibly due a cascade SPD set up using Type I at the service and Type II at the branch panel.
What is interesting is the owner stated some drivers failed during a non-storm event.
Will a SPD help protect against Temporary Overvoltages from a Utility (if that is what happened)?
Can wiring issues from old wiring cause this?
Given the age of the facility I doubt there is good intersystem bonding. Is there a cost effective way to check bonding/grounding?
Would it make since to bring in an electrical contractor with power monitoring equipment to clamp the service and record?
The set up is Simens SP1 2000A switchgear, then feeds a 800A GE distribution board, then feed a 100A lighting branch panel. All 20 years old or so.
