hbiss
EC, New York NEC: 2017
- Little Falls, New York NEC: 2017
- EC
So, I stop by to see my buddy, a fellow EC the other day and he says let me show you something. He has an LED flood light, your typical cobra head- only with a bracket to mount to a wall. Lithonia I think. Anyway, he removed it from a gas station because the owner complained that after around 20 minutes it went out. It was in service for about 3 years with no issues. So he brought it back to check it out. On the top there is a compartment that contains the power supply and he figures it must be bad so he orders a new one. When he shows it to me the new PS has already been installed and he says that it still goes off after 20 minutes. You have to remove power and it lights again. Hmmm.
He takes the cover off and I check if it's the same as the old one, and it is. Mean Well HLG-320 here:
http://www.meanwellusa.com/productPdf.aspx?i=337#1
So I figure let's plug it in with the power supply sitting on the bench outside the fixture and see what happens. After awhile I touch the PS case feel very little temperature rise but the fixture is as hot as hell. My hunch was that the power supply was being overheated, and sure enough, with the power supply out of the fixture it continued to operate just fine.
For giggles, I say lets measure the 120V line current draw and it's an amp more than the 3.5A rating on the label. I don't know if that means anything, but for sure the fixture LEDs are generating too much heat. If you look at the spec sheet under protection, when an over temperature condition is detected it's designed to shut down and latch off output voltage, re-power on to recover. Which is exactly what it's doing.
So what about the LEDs? When they age do they draw more current and generate more heat? This power supply is a constant voltage design, perhaps a constant current supply would have been better suited?
I just advised that he try and return the replacement power supply and get his $100 back then tell the customer he needs to replace the fixture.
-Hal
-Hal
