LED Light Mounting NEC
cws3rd
New User
Ziggy1969
Realtor/Builder
Hey Gents,
I am new to his forum and would greatly appreciate any thoughts on the matter. I have built a new 40 x 64 metal shop with 14 ft eve height and 20 peak height. Shop has metal columns, rafters, and skin with wood purlins and girts. Anyway, I am mounting the new 8 ft long LED lights to the metal rafters using black plastic zip ties rated at 50 lbs each. The LED light itself weighs 2 lbs total and is about 1.5 inches in diameter. NEC 314.27 requires 50 lbs support (I believe).
Your thoughts? Are zip ties not considered "permanent"? Would metal zip ties qualify? Because of the metal attachments on the bottom of the rafters, there is no way to mount directly to the rafter without fabricating spacers and drilling through 1/4 inch steel. These lights weigh 2 lbs each and are only 1.5 inches in diameter. Thanks!
This site is designed for:
  • Contractors
  • Electricians
  • Engineers
  • Inspectors
  • Instructors
  • Other electrically related individuals
This NEC® Forum is for those in the electrical and related industries. Questions of a "How-To" nature by persons not involved in the electrical industry will be removed without notice.
Knowledge and the practical application of the National Electrical Code is an essential part of all electrical installations. If it's important for you to understand the National Electrical Code, then look no further.
To better help us serve you, please be sure to update your account details with your occupation field and location if you have not done so already. You can access your account details by clicking on your account name at the top right of the page when on the forums.
