Led Lighting
Mr. Bill
Michigan
16' and only 48W from the 300 LEDs. The website is a bit sparce on information. If the customer is okay with the cost I think the main issue will be lack of light if this is being used as an undercabinet task light in the kitchen. And in 5 years the double sided tape used to mount this light ribbon may loose its stickyness. An insullated staple may be preferable.
Mr. Bill
Michigan
I say it's not going to be enough light because of the wattage. Without the company providing any lumen output levels or LED manufacturer/product id I have to make assumptions. I assume it's more of a generic quality LED with light output about 50 lumens/watt. (Which I think is generous) 48W * 50 lm/W = 2400 lumens for the whole 16.4 foot length. A 4' 32W T8 lamp puts out about 2950 lumens. Slightly less light output spread out over a length that's 4 times longer. [2950/4)/(2400/16.4) = 5.04:1
Per linear foot, this will put out 1/5th of the light as a single T8 lamp.
Dennis Alwon
Chapel Hill, NC
Retired Electrical Contractor
ptonsparky said:
Anyone have experience with the GMLighting LED Ribbon?
Looks good, pricey, simple to install - something has to be wrong.
www.gmlighting.net
Incandescent rope lighting is somewhere around 5.5 watts/ft. The ribbon is only 3 watts /ft. I guess it would depend on the installation whether you would have enough light. If it is just mood lighting it may be just fine but I would prefer a little more wattage / foot. I guess you could double the run but that stuff is expensive compared to the regular rope light
EC - retired
We had about an 18" sample to look at. Suprising amount of light in her daylit kitchen. The sticky bothers me to. We will stick it to a cleaned metal or glass strip of some sort then fasten that to the upper cabinets. Comparing lumen output via wattage comparisons is not valid.
