Sparky2791
- Northeast, PA
- Electrical Design
The NEC has minimum pole heights for pole lights being fed with 480V. This applies to auxiliary equipment for electric discharge lamps. What if the pole lights are LED? There is also a footnote in the handbook to see 410.137 for auxiliary equipment limitations which is just more confusing.
I need some clarification on this. I have an LED pole light I need to circuit with 480V due to voltage drop but the township it where it will be installed in has a pole height limitation of 16'. The LED driver is part of the luminare mounted at up on the pole not separately.
Any input will be appreciated.
210.6 Branch-Circuit Voltage Limitations. The nominal
voltage of branch circuits shall not exceed the values permitted
by 210.6(A) through (E).
(D) 600 Volts Between Conductors. Circuits exceeding
277 volts, nominal, to ground and not exceeding 600 volts,
nominal, between conductors shall be permitted to supply
the following:
(1) The auxiliary equipment of electric-discharge lamps
mounted in permanently installed luminaires where
the luminaires are mounted in accordance with one
of the following:
a. Not less than a height of 6.7 m (22 ft) on poles or
similar structures for the illumination of outdoor areas
such as highways, roads, bridges, athletic fields,
or parking lots
the following:
of the following:
or parking lots
