gar
- Ann Arbor, Michigan
- EE
160804-0918 EDT
Two nights ago I went out after dark in my Escape. Several days earlier I had put an Feit 10 W (so called 60 W equivalent) LED near my main panel. This was on at the time I left. I am usually tuned to 760 AM, WJR Detroit. I park my car in the breezeway all the time. This has a plaster ceiling with metal lath. Thus, somewhat of an RF shield.
Signal strength is less in the breezeway than in the driveway resulting from the metal lath shielding. WJR in years past was a clear channel station with a 50,000 W transmitter located possibly 40 miles away. I believe WJR is no longer a clear channel station and has to reduce power somewhat at night.
This discussion https://en.wikipedia.org/wiki/WJR seems to imply that WJR is still a clear channel station. But I still believe that signal strength is lower at night. I am at ground path range.
Some of the history mentioned is interesting. In 1936 my dad took a night class in radio broadcasting that was conducted at WJR. Close in time to when WJR became 50,000 W. My dad took me to a couple of the classes.
One was at the WJR studio and I remember the microphones from there and the room was fairly large. The other time was a trip to the WJR transmitter site. There I saw the very large vacuum tubes for the transmitter. These were long, had a copper (probably alloy) shell that would be the plate electrode (greatest heat generated at the plate), were water cooled, and I did not understand how they could use water cooling because most water is conductive, and as a small kid I thought all water was conductive. I believe they used distilled water.
The circuit could have been designed to have the plates grounded. There were two idential transmitters so that when one failed (tube burn out) they could immediately switch to the other. There was a speaker there and the audio quality was very good.
The antenna was about 7 or 8 hundred feet tall. One wavelength at 750 kHz is 1311 feet so some antenna tuning was done.
Also visited the WWJ transmitter and it was a lower power.
Back to noise. In the breezway I noticed a lot of static noise on WJR. Pulling out into the driveeway the noise reduced a little, and pulling under the primary line that runs along my street the noise increased a little, but not to the magnitude that existed in the breezeway. In retrospect the wires feeding the street light run below the primary lines and connect to the secondary of my pole transformer.
Today with WJR at daytime strength I ran a test with the LED and any other known noise makers in the house off. Other noise makers are phase shift dimmers and other Feit LEDs. There was no background static, in the breezeway or under the power lines. Then turned on the one single LED near the main panel and some static noise was present in the breezeway and under the power lines. Thus, this bulb is the source. Noise level is not as high as at night. Thus, I still believe WJR is lower power at night.
I had previously discussed LED RFI when I ran some bench tested. Not all LEDs are this bad.
