Knick
- Grand Rapids , MI
Hello
I am currently changing over some of our production lighting to LED tubes. Our current set up is a 8 lamp 32 watt with T8's, 3 Ballast's per fixture and a battery back up if its a emergency fixture. The new LED's are the style that you remove the ballast and wire direct to line voltage. This works fine accept on the emergency fixtures with battery back up. I found a kit that will work with the LED'S but it was like $350 per fixturehmy:. Have any of you found a way around this? LED lamp that will work with our existing emergency setup? One that is more economical? any other ideas?
At this point we are looking at just changing over everything but E-lights
Thank you
Knick
Thank you
Knick
