I have yet to run into this on an LED retrofit, but are wondering if any of you out there have. I like using "Type B" double ended led retrofits. If using this type, the issue I see is that you would be running line voltage to the slave fixture through its existing cable assembly. I know some folks are weary of just putting line voltage on the tombstones on a regular retrofit, but I'm generally ok with that, assuming 120v, decent tombstones, and a sticker is affixed. This is taking it to a different level for me, though. Is this a Code or UL violation? Thanks!!!
