twisteddough
Since the voltage is in the 12 volt range and the current is limited,my question is : Does the sign (outdoor) need a disconnecting means at or on the sign? Help..this sign is 80 ft in the air on a building.
Dennis Alwon said:You still have higher voltage going to the led driver.
iwire said:It would not matter if the sign ran on a 6 volt supply, 600.6 requires some sort of disconnecting means. :smile:
Dennis Alwon said:I realize that but it seems I confused things-- I was just trying to make a point of the low volts to the sign. I quoted the exceptions and I thought that claified it.
