Promised a friend I would post this, doesn't live near me or I'd check it out myself.
Has an LED strip light installed in his garage, one of three fixtures on the circuit but the only LED. He said he replaced a fluorescent strip because the ballast failed.
When he turns the switch on, if the fixture is cold the 15 amp GFCI breaker will trip. When ambient temperature is warmer, breaker does not trip. He has tried swapping the GFCI with a standard 15 amp breaker and it holds under similar temperature conditions. Says he has inspected the wiring inside the strip and cannot find anything suspicious. He going to try swapping it with another GFCI breaker (although it's a 20 amp) to see if it holds, outside temp is plenty cold today.
Is this just likely a faulty fixture?
