brantmacga
Señor Member
- Georgia
- Former Child
I'm having a hell of a time trying to find a fixture that is suitable for this;
The building is insulated steel that is used as a produce cooler, but is also unconditioned at times. The temperatures at the roof can easily go over 100 degrees.
The current fixtures are F96T12HO; the owner is looking for something with less maintenance; preferably none. They are surface-mounted on the steel beam at 17' aff. Also, I need to match or exceed the output of the HO fluorescent fixtures; along with ambient temperature and ceiling spacing issues, this has been a problem.
Almost every LED option i've looked at requires it to be suspended around 24" to keep the ambient temp rating. I found one at lithonia that didn't require this on the spec sheet, but after speaking with a lithonia rep, I learned that the 24" suspension would be required.
This isn't an option because of forklift traffic in a narrow aisle; it must be a surface mounted strip style fixture. I'm currently waiting on a quote for Cooper HBLED fixtures, which they have told me will work in this application, but wanted to check with you guys for any additional ideas.
