I have a switched outlet in a pantry.
On the other side of the wall is the stairwell with a sort of architectural feature I'd like to get a small wire into to light it up from behind. From there id like to go through the wall again to get through to the other set of stairs heading to the second floor to light up the stairs a little.
The details don't matter so much. What I am after is the best low voltage solution to this sort of problem. I'd like to leave the switched outlet with someone like a cat 5 wire, light up a small LED strip, continue with the cat 5 to end at some sort of stair light.
I'm not familiar with all the low voltage LED options out there so looking for recommendations/options
thanks
thanks
