smoky
- akron, ohio, united states
a contractor installed LED troffers. they ran 277 and a N through FMC but didn't run a ground wire. when the contractor was asked why there is no ground, they said the ground isn't necessary because the lights are LED.
this is in an industrial facility. i'm only mentioning that because they also didn't install the luminaries disconnect in the fixture's stuffing box. when i researched if the disconnects are to be there, the code appears to exempt industrial buildings.
