LED Under Cabinet Lighting
EC - retired
I sold some last fall. Came in a 15' roll with adhesive backing. The customer loved it. This model was very bright and not dimmable. No complaints yet. Other versions are dimmable and have a softer light. Black polished counter tops reflect each lamp and could be annoying to some. See if you can get a small sample strip to take to the customer. My supply house had one available. Expensive, with numerous fittings to contend with if you have very many corners or splices to make.
chris1971
Usa
I did see the self adhesive style LED lighting at the wholesale house. I assume a power supply gets mounted somewhere to run the LED lights?
