Did anyone ever amp probe a 2x4 T8 4x32w, against an equal 2x4 LED, with similar lumens ?
 I was just messing around at lunch time, and the amp difference was not all that much.    I was not overly impressed with the amp reduction.   Maybe the ballast and bulbs won't need replacing as often, but I'm not so sure about the energy savings.....    New construction, yes, but to retrofit T8's and go through the expense... is it really worth it ??
Factors that affect the total efficacy of a T8 system is in this order:
------Fixture reflectors and optics
---Lamps
--Ballast (assuming it's an electronic)
The most efficient T8 fixture can hit 90% and provide a fixture level efficacy close to 90 lm/W. For example.. specular reflector high bays. For indoor ones, best ones are usually in high 80s.  Old ones are routinely 50-70%.
A drastic reduction like going from 4 x F40T12 magnetic ballast system to 2 x F32T8 is made possible when going from very inefficient troffers with F40T12 to 85% efficiency fixture with 3,100 RE80 lamps and matching the mean lumen or getting slightly below it.
If one goes directly to LEDs, the symptom of increased efficiency is often misdiagnosed as having been caused by LEDs, but it's really not correct.
Now, when you have a 12mpg approaching end of life, a replacement to 25 mpg vehicle is a no brainer.
With the latest and highest performance LED, it may get you say 28 mpg, but the added cost is hard to recover.
Scrapping your current 25 mpg with 60% life left solely to buy 28 mpg one to save on gas...?
You may save on gas, but remember that the upgrade cost a lot of money and you may never get out of being upside down.
Troffers designed on 1950s and 1960s template do not employ computer aided drawing and precision crafted reflectors with high efficiency in mind. The smaller size of T8 lamps does allow for somewhat more efficient optics given the same fixture depth allowance and even more so for T5.
F54T5HOs are less efficient at lamp/ballast level, but it makes up for it in some applications through a high fixture efficiency. 3 and 4 lamp, especially 3 lamp T8 troffers are not very efficient. Under the right conditions, one F54T5HO can replace a 3 lamp T8.   (cheapest 700 series lamp with 2600 mean lm x 0.88BF x 3 lamps x 60%) =4,200 lm vs (4800 mean lm x 1.0 x 85% eff ) =4080 lm
But the biggest trick to the magic is that existing fixture must have poor efficiency. If they have a <10 year old electronic ballast, recently wiped down and freshly loaded 28W RE80 lamps, there's hardly a benefit in early retirement.
