Led
hhsting
Glen bunie, md, us
Junior plan reviewer
Site light for ATM machine for bank has led 208V single phase rating while its being fed from 240/120V panelboard single phase. I believe the service is 240/120V single phase. Anything in code to stop this or is that ok?
There is nothing in the code that's going to prevent you from burning up a site light fixture.
JAP>
Do they make 208/120V single phase panelboards? All I see is 240/120V single phase panelboard.
There is no difference. You would simply use the latter for the former.
Think of the voltage ratings as maximums, as with receptacles, etc.
If the _service_ is 208/120V and you tap 2 legs of it and a neutral for a single phase panel, then you will have 208V l-l at the panelboard. You can use a 120/240 rated panel for this application.
You stated in the first post that the service was 120/240V single phase. In which case you will have 240V l-l at the panel.
If the lamp is rated for 208V only, then you can't use it, you don't have the proper voltage available.
-Jon
General color code for 0-10v dimming would be Purple and Grey, not Purple and Brown.
Asking what colored wires do without us actually being able to see the ballast or driver drawing is a loaded question that actually cannot be answered that easy.
JAP>
